Adjusting valves for solid roller
Adjusting the valves is relatively easy - you just rotate the engine a few times stopping as specific cylinders come to the right position to adjust the clearances. The most time consuming part is usually removing the other parts that are in the way - coils, valve covers, radiator, etc. The frequency varies, but once every 10k miles will usually work. If you are racing alot, you would likely check clearances before every event.
