LQ4 build help
LQ4 build help
Ok, well I've decided to pull the LS1 out of my Z28 and sell it to get an LQ4 to build and put a lot of spray on. What I'm wanting to do is use the stock LQ4 crank, get a good set of rods and pistons, a nitrous friendly cam, L92 heads with an LS3 intake. I need suggestions as to what kind of rods and pistons to use, what valves and valve springs, what cam would be good for the setup and any other parts and advise you guys think will help.
Thanks in advance for any information given!!
