who has bored out a ls1 to put ls2 pistons in it
Old 07-24-2011, 04:51 PM
jjbiggers2's Avatar
Default who has bored out a ls1 to put ls2 pistons in it
I know its not recomended but who has done this? I have heard it can be done. I have a ls1 block that needs bored and a set of stock ls2 pistons.
Old 07-24-2011, 04:56 PM
ls1 1990 VN's Avatar
LS1 Alloy block can't be bored...honed from standed 3.903 piston to 3.905/3.908
Old 07-24-2011, 05:05 PM
jjbiggers2's Avatar
I know that's what they say but I have read about people that have did it.
Old 07-24-2011, 05:21 PM
NVR_SPDS's Avatar
I believe the stock bore is 3.898, and can only be cleaned up to the 3.903/5/8 aftermarket pistons.
The walls just arent thick enough to safely support the bigger piston. Your pretty much rolling the dice on if it will last.
Old 07-24-2011, 06:19 PM
blk~2000~Z28's Avatar
possibly after resleeving their blocks, which at that point it would make more sense to get a different block anyhow.
Old 07-24-2011, 07:12 PM
Canbarelygo's Avatar
dont try to cut corners youll end up with a wheelbarrow filled with a thousand buttholes and a junk block. use your head.
Old 07-24-2011, 08:40 PM
mmmmm 'BUT' is this not what i said!!!
Old 07-24-2011, 09:23 PM
Cape T/A's Avatar
Why would you not just buy some forged pistons while your inside the engine and then youll be able to take some abuse from power adders.
Old 07-25-2011, 06:15 AM
jjbiggers2's Avatar
The cylinders are to pitted from rust to make 3.908 bore size so that is why I was thinking of doing the ls2 pistons I have.
Old 07-25-2011, 09:35 AM
Isolde's Avatar
If you're gonna bore it, try for 3.936". If it cleans up there, you can get it honed to 3.94", order rings for a 0.030" overbored Mopar Magnum 5.2L, then order custom forged pistons to match, and have more safety margin than trying for 4.00".
But it might be cheaper to just buy a used LQ4.
Old 07-25-2011, 10:56 AM
kinglt-1's Avatar
This guy did it...
https://ls1tech.com/forums/dynamomet...s-xr281hr.html
Old 07-25-2011, 03:37 PM
jjbiggers2's Avatar
I knew I saw someone that has done it.
Old 07-25-2011, 03:53 PM
BlueBird346's Avatar
Read the replies in that thread. Its not a good idea.
Old 07-25-2011, 04:57 PM
SilverSS's Avatar
a 4.000" bore will leave your sleeve wall thickness at around .027" thick in an ls1 block. the grey iron sleeves are brittle and the aluminum supporting them is a joke.
Old 07-25-2011, 05:35 PM
89 formula350's Avatar
hard to say how long it will last. ive seen cylinder walls break open on gen 1 blocks. i think for the "chance" labor you had the machine shop put into this I would have tried sleeves for a fun chance. go big right off the bat
let us know how it goes. might just find the walls distort after time and poor sealing of the rings is all that happens
Quick Reply: who has bored out a ls1 to put ls2 pistons in it
