2000 trans am 6.0 f1 build
Old 07-31-2011, 11:24 AM
lbm13186's Avatar
Default 2000 trans am 6.0 f1 build
hey every one im putting together a f1 pro charger build on a 2000 trans am, i swapped out the 5.7L to a 6.0 and put a brute force fi cam and all new pistons and beams ect. i also up graded the fuel system to twin in tank from lonnies performance. i plan on starting out with about 8 lb of boost to start out and when the motor get broken in then ill step up to around 12 lb
now im about to install it and i need a little help on the spark plugs i should use i have been thinking about using NGK BRF7s and i was wondering what everyone thought about them please let me know.
thanks for any help you may be able to give
