rotating assembly with billet rods rated at 850whp?!?
Old 08-01-2011, 04:05 PM
IKnowtheFuture's Avatar
Exclamation rotating assembly with billet rods rated at 850whp?!?
whats up with that? are they under rating for liability reasons? the kit it howard rods, compstar crank, mahle pistons.
Old 08-03-2011, 02:28 PM
tim99ws6's Avatar
It's more the pistons than anything. The crank and rods are not your limiting factor, but that low end forged alloy in a piston leaves little room for error. Upgrade the piston to a 2618 alloy, and I'd put it to work at 1000 all day assuming everything else is up to task.
Old 08-04-2011, 12:42 AM
Whish ones do you reccomend. they said I can switch out pistons but they dont have wiseco and iirc not diamond either.
Old 08-04-2011, 07:49 AM
tim99ws6's Avatar
Je, cp, anything that's 2618. Who are you getting this from? What piston options do they have?
Old 08-04-2011, 11:59 AM
Fbodyjunkie06's Avatar
Wiseco really makes a nice coated piston nowadays. If you can try and stick with them in a higher strength alloy.
Old 08-04-2011, 03:16 PM
howards cams
