PRC Stage 1 LS6 Heads
Old Apr 16, 2011 | 10:12 AM
DaveCZ06's Avatar
Default PRC Stage 1 LS6 Heads
How much of an improvement are these over stock LS6 heads? I'm trying to figure out if its worth the money, since I'm swapping the cam anyway, may as well do the heads too.
Old Apr 16, 2011 | 12:01 PM
'02 WS6's Avatar
They're a big improvement. Know a few people that have ran them paired with the right cam and pull 450rwhp+....myself included.
Old Apr 16, 2011 | 02:37 PM
BrntWS6's Avatar
I plan on getting the stage 2.5's here shortly. Can't go wrong with the PRC's
Old Apr 16, 2011 | 03:19 PM
OhTwo's Avatar
Heard the same as '02 WS6 above. I went with the 2.5 heads myself and getting everything put together now. I expect to see good numbers with my new heads and cam.
Old Apr 17, 2011 | 04:05 PM
zacht's Avatar
id like to see some more real world info on these too! i bought a set used on here. i have yet to put them on.
how do these compare to AI 243's?
Old Apr 17, 2011 | 04:50 PM
brians91formula's Avatar
AI 243s are better if done up right imo.
Old Apr 17, 2011 | 07:33 PM
mike c.'s Avatar
I see so many people talking about the prc heads,but can't find a lot of dyno and the real test track times vs weight of car. The dyno not so big due to one dyno having my old set up at 423hp and another dyno had th same set up at 395hp. I would like to see if they really make power by running down the track mph vs weight of car..
Old Apr 18, 2011 | 10:09 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Have you run both?
OP: Typically we see about 40hp/30ftlbs from the addition of our Stage 1 LS6's over the stock LS1 heads. They represent a great bang for your buck cylinder head and have been proven time and time again on the rollers and at the races!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Apr 18, 2011 | 12:24 PM
Rare96LT1Formula's Avatar
Before you buy your cam, get the heads. Then you can have a cam spec'd to your heads. I've heard many good things about Advanced Induction, and I've heard of gains of 55+ rwhp with their 243's worked over. I've considered myself finding a set of 243's used, buy them, then send em in to AI and have a cam spec'd. However, I think I'll likely end up going with a PRC heads/cam package from TSP. I've heard great things about their 5.3L stage 2.5's, so that is the package I'll probably go with.
Originally Posted by Matt@Texas-Speed
Have you run both?
What kind of gains would you anticipate from the addition of Stage 2.5 5.3L heads over the stock LS1 heads?
Old Apr 18, 2011 | 12:50 PM
DaveCZ06's Avatar
Have you run both?
Thanks Matt, couple more questions before I pull the trigger on the order button.
I have an 04 Z06 with a build date of 08/03. Will it have the head bolts that are the same length, or the varying length head bolts?
Also are LS6 and LS1 heads the same? If theyre that big of an improvement over stock LS1 heads, and LS1/LS6 has different heads, what kind of improvement are they over the LS6 stock heads?
Old Apr 18, 2011 | 01:06 PM
ZexGX's Avatar
LS6 and LS1 heads are not the same. LS1 heads of that year are casting # 241. LS6 heads are casting # 243. Aside from the different chamber and intake/exhaust runners, the springs/valves are also different. Out of the box, AND after porting, the LS6 head is a better flowing head.
Old Apr 18, 2011 | 01:11 PM
With that build date, I'd expect it to have the long/short early style bolts!
__________________
Old Apr 18, 2011 | 01:13 PM
DaveCZ06's Avatar
Thanks Matt, do you have any rough idea what these heads would gain over the stock LS6 heads? Also if I call you guys up, can you put together a custom order with both sets of bolts, just in case?
Old Apr 18, 2011 | 01:19 PM
Over stock LS6 heads, the Stage 1's are going to be worth about 25-30hp or so. Of course, give me a call!
__________________
Old Apr 18, 2011 | 01:47 PM
DaveCZ06's Avatar
Thanks for the help Matt...did a little more research and got my order squared away online. I'm glad too, I didnt feel like having to find a phone to use; Afghanistan sucks!
Old Apr 18, 2011 | 01:56 PM
Got it processing! Shoot me a PM with your cam specs if you'd like us to mill them to bump your compression for free!
__________________
Old Apr 18, 2011 | 08:18 PM
DaveCZ06's Avatar
Thanks Matt, PM sent!
Old Apr 18, 2011 | 10:00 PM
SATAN's Avatar
Do the 317 heads from the LQ4 flow the same as the LS6 heads? I understand the combustion chamber is larger, but flow wise, are they the same? I have just heard that besides the combustion chamber, they are the same casting...
I am about to go look on the texas speed web site to see if I can find prices for porting. If the info is not there, could you post up a link so I can see the pricing somewhere?
Old Aug 4, 2011 | 03:32 PM
427LS7HCI's Avatar
subscribing
