ls1 - gen3 block confusion.
Ok. So I get my car tuned. That went well. Actually, it's awesome. He actually rewrote some lookup tables with HP Tuner software...but save that for another thread. The guy told me it was tuned for a 160F thermostat, which we had mutually decided I'd put in at a later time. So, naturally, he sent me home with a print of this. So I ordered this one. Yeah, well, I though I'd save some money cuz Jegs only wanted 0$ for shipping whereas TS wanted 14.30$...anyhow....jegs added 9.9 handling and 2.50 for some delivery surcharge...but whatever.
So, I take it to get installed and they tell me that it's the wrong part. They then call Hypertech and they say they don't make one for my engine.
Apparently, I have a gen3 not and ls1. again i'm confused They told me its a 346cu in., 5.7L, Vin Code G, Gen3 block. HHHmmm.
Go easy on me. Now, I'm not a car guy, so that's why I'm writing this. I saw some stickey somewhere how to tell what engine block a person has in their car. (I think)....but couldn't find it.
How can I tell, undeniably, what engine I have in my car?? Therefore, I can get the correct part(s).
What is difference between a gen3 and ls1?
Thanks for your time and tolerating my naivete.
the 1st gen Small block came out in 1955, gen2 aka LT1 came out in 1992, the 3rd Gen aka LS1 came out in 1997, the 4th gen came out in 2005 and is the LS2
your 2002 TA came from the factory wht the 3rd gen LS1 in it.
It's not necessarily the "block", it's more dependent on the pump. If you still have the factory water pump, you'll need the early style one-piece thermostat that comes with the housing. If the pump has been changed, it could possibly take the later two-piece style (separate t'stat) depending on what pump was installed.
Besides all that, you can add shims (pop rivet washers) under your factory t'stat to make it operate at a lower temp. Do a search...
A Gen 3 is not an engine, its a series of engines. They made Gen 3s in 4.8, 5.3, and 6.0s for the trucks, most were cast iron but there was a High Output 5.3 that was aluminum. The f-bodies, vettes, and GTOs got the Gen 3 5.7. It was code named the LS1. All other engines had 3 letter names as well but most just know LS1 because its the "high performance" Gen 3 I suppose. Basically all parts interchange between the 4 engines.
Whoever is working on your car, re: water pump, 'SHOULDN'T BE' if they don't know the difference between pumps, thermostat included (one piece) & pump with separate thermostat i would be taking my car else where.
For them to phone Hypertech then relay to you that information about not making one is just utter crap, they need a bloody good
but yeah gen III ls1 5.7
I've been taking it to a guy I've known for over ten years. He's been working with cars for probably 30. So, I'm pretty sure he knows of what he speaks.
He just gave me a printout using my vin. It states it's a 5.7 L 346 CID V8. The LS1's are 350's right?
yes if you have a trans am 98-02 it is going to say you have a 346 cid 5.7 (ls1), But that may not matter in your case since you do not know if your engine is the factory engine that came in your car. Can you get the numbers on the rear of your block??
Yep. That's what I was planning on doing. I'll get at it tonite and see what I can read.
i've read through both of your threads. 5 pages. please just crawl under there and get us some numbers
edit: i'm not really mad just curious. and btw my guess is its a stock ls1 block. 5k or whatever into the engine and you would see much more going on than is there. dealer was just conveying bad info.
crapcrapcrap.
I tried to feel/find it but could barely fit my had on back side of block.
Anyone have any luck getting the block casting number w/out lifting the car up?
If so, how'd you do it?
