Lpe gt7 cam question .
Old 08-29-2011, 10:25 AM
Blk_Ws6's Avatar
Default Lpe gt7 cam question .
How well will this cam do in a 02 ws6 with PP Patriot heads II , an a ls6 intake pp throttle an Longtube headers , What do you think about this set up , not looking for a lope at ALL daily driver. all answers welcome.
Old 08-29-2011, 10:26 AM
Blk_Ws6's Avatar
gt7 cam :208/230 .554/.546 121CL
Old 08-29-2011, 10:33 AM
kinglt-1's Avatar
its a forced induction cam for 1 and 2 its about the size of a ls6 cam but with a huge split in duration. I say look for something else...
Old 08-29-2011, 10:36 AM
Blk_Ws6's Avatar
What would you suggest King ? something they won't hear coming ?
Old 08-29-2011, 10:59 AM
kinglt-1's Avatar
the gt1 would be much better, but has a slight lope.
http://www.streetfire.net/video/57l-...aust_26897.htm
Old 08-29-2011, 11:08 AM
Blk_Ws6's Avatar
Yea that's a bit choppy ,what do you think about the cheatr cam v3 /
Old 08-29-2011, 11:09 AM
kinglt-1's Avatar
These would be great options also...copied from AI's website
"High Mileage Grinds
These are a few of the grinds we commonly run with OEM GM "Yellow" springs & other light beehives. They are very mild - like the OEM GM cams used in solid stem LS1/LS2 valve applications. Paired with high quality beehive springs like the PSI MaxLife, Manley Nextek, or PAC 1518 the spring change interval is typically 50k+ miles. These are normally run on 112-120° lobe separations.
•Ai 210 / 222 - .554" / .545"
•Ai 214 / 222 - .565" / .545"
•Ai 223 / 232 - .560" / .570
Old 08-29-2011, 11:13 AM
kinglt-1's Avatar
the 113 lsa is giving it the chop. if that cam was ground on a 115 it would idle smooth.
The cheatr v3 has too much split imo...unless you plan on sticking with stock manifolds and y. That cam is designed for exhaust restriction. Your best option would be to call ai tell them you are interested in a high mileage grind, I would suggest the 214/222 or 223/232 on a 115-116lsa.
Also the tr tru torq 1 would be a good choice, 219/224 on a 115lsa, although it has more agressive lobes than what I listed above. You need to check springs every 10k mi and probably change them by 25k mi. samething for any .600+ lift cam...
the "old man cam" from tr would be a good daily driver cam also.
Old 08-29-2011, 11:18 AM
Blk_Ws6's Avatar
Originally Posted by kinglt-1
na too much split...unless you plan on sticking with stock manifolds and y. That cam is designed for exhaust restriction. Your best option would be to call ai tell them you are interested in a high mileage grind, I would suggest the 214/222 or 223/232 on a 115-116lsa.
Yea King , that 214 22 calling my name yea where you get this from I would like it on a 117lsa.
Old 08-29-2011, 11:20 AM
Blk_Ws6's Avatar
That 214 222 on a 117 with the pp heads an ls6 intake where will I be at with this one?
Old 08-29-2011, 11:33 AM
kinglt-1's Avatar
probably close to 400whp and drive like stock. sounds like a great daily driver combo!!
http://www.advancedinduction.com/LSX/AiLSxCamsHR.php
Old 08-29-2011, 11:35 AM
Blk_Ws6's Avatar
Thanks bro .
Quick Reply: Lpe gt7 cam question .
