LS4 oil pump ??
Old 09-02-2011, 09:58 PM
02blackbeauty19's Avatar
Default LS4 oil pump ??
I ordered a LS4 oil pump (GM #12571885) and it just came in today and it has a part number of 12571896. Can anyone confirm that this is the same pump with maybe a replaced part number?
Old 09-02-2011, 10:42 PM
01ssreda4's Avatar
Whats different about the LS4 pump from a standard LS1/6 pump?
Old 09-03-2011, 05:29 AM
Higher pressure
Old 09-03-2011, 05:38 AM
Restricted User
jalper's Avatar
why not use a aftermarket pump, is the ls4 pump better or just have more pressure.
Old 09-03-2011, 05:41 AM
I have an aftermarket pump, too.
I'm just looking to see if the part numbers are interchangeable.
From the website:
This GM oil pump is known as a "high volume" design used on the 2007 and later LS4 5.3L W-Body applications, the LH6, LC9 5.3L Trailblazers, SSR's, pick-ups, SUV's, 6.0L and 6.2L engines with Active Fuel Management (AFM) . GM engineering determined that the increased oil volume was required to meet the demands of the AFM system.
This pump uses a thicker gerotor with a slightly larger OD than the 12586665 standard volume pump. Dimesionally this pump is identical to the 12571885 high volume oil pump but is uses a different by-pass spring!
Quick Reply: LS4 oil pump ??
