no head markings?
no head markings?
My car came with an extra set of heads that were on the original motor. But I can't find a 241 marking anywhere did they make some of the heads without markings? They also have dual valve springs did any heads come with dual valve springs stock? The only numbers are 0305218537038925 which is right below where the 241 would be and at the opposite end is: 3052r8493924.
What the heck are these heads?
Aftermarket companies often shave stock part numbers off when they modify parts. Prime example is rejetted stock injectors. What if they float to someone who doesn't know what they flow and use the part number to verify their origin? Same with heads, or anything else. Once its no longer a "stock" unmodified part, the number comes off.
