Pushrod length and valve spring suggestions NEEDED ASAP!!!! PLEASE
I just bought a pair of 317 heads with new valve job and milled 30 off. Puttin a cam with a 236/242 duration and .580/.590 lift with 112LSA. Puttin it on my ls1 stocker block. I have pacesetter LT 3in ORY into a flow. Have stock 98 LS1 intake with whisper lid and TB bypass and screen deletion. Has stock 28lb injectors. Also 11.5lb ram flywheel. What should i be puttin down after L&G perfect tune?? Also i need pushrod length recomendations and would i be ok with a single behive .595 lift spring or... Please fill me in. Also what head gaskets are best for the price
Y would i have P2V cleaRance issues?? Ive seen tons of people with this setup and cam duration. I dont think P2V clearance should be any kind of issue with these 317 heads milled 30 down. They are low comp heads anyway, or may i have trouble??
