Good turbo cam
Good turbo cam
Its finally time to build so the question is who to get the cam from. This is my DD so needs to be streetable. What you guys recommend? Ive got a 70 mm precision turbo, just trying to decide what cam to go with.
LS1 Tech Administrator
Tell us more details about your turbo kit. A/R ratio of turbo? Manifolds, logs or tubular exhaust? Intended boost level? Anticipated rpm range? What's your application? What are your power goals? Auto or manual?
Turbo cams are some tricky beasts to cam correctly and you've left out the answers to 97 out of 100 questions I would typically ask before giving a recommendation. The questions above are obvious ones just to get in the ballpark.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
As i sit its a stock ls1. The turbo goin on is a 70mm Precision 96 A/R. A2W intercooler, heat exchanger. Im having the headers built by a friend and will be front mount. As far as rpm range not really sure first turbo ive messed with but prob in the park of 2,000 to 5,800 if id have to say. Ive got 5,8,and 11 pound springs for boost levels. Car is a 6spd w/ 373posi in rear. My goal, id like to see between 500 to 600 rwhp with Cam, boost and tune.
No i dont want too radical just yet. Just a fun street car with ***** to back it up. Ive got friends with too much ******* money that are producing retarded #'s on the dyno just trying to somewhat keep up lol.
I wouldnt say rich, just dont have kids and family like i do, Oh yeh and they have great paying jobs lol. They mainly have stangs, Goats, and few others. But the half the guys with stangs are running LQ engines with spray, and the goat boys are all boosted. Im the lowest on the poll with HP at 300. They all sittin between 600-1,000 HP.
Just having a turbo laying around is 1 thing, but do you have EVERYTHING to go along with it and do it right/correctly is another? Cam wouldn't be so high on my list right off the bat, but hot/cold side pipe layout, fuel system, intercooler, meth kit, controllers, guages, etc..... would be more inline imo.
Headers are being built, Intercooler, Heat exchanger,BOV,wastegate and other lil things are chilling with turbo. As far as the other goodies ive got to get. And everything will be done right or not at all. I dont have a couple grand just laying around to cut corners. Ive saved my lunch money for a while for the build! LOL
If you're not looking for huge power numbers you may take a look at the LS9 cam. They can be had cheap, drive like stock and are a good turbo grind IMO.
Just remember that they do not come with a cam sensor reluctor in the back so you'd need a 4th gen front cover and cam sensor extension.
I'm running a turbo cam with 222/226 @ 050. Lift is 0.575"and lobe centers are 113/116.
Cam was worth a tad under 50rwhp before adding the turbo over stock but that included slightly tighter head gaskets, stiffer springs and beefier pushrods.
6lb boost was 450rwhp on my old Ls1 with auto. It has a noticeable idle and makes more power everywhere than the stock cam.
Only downside is mpg is down 15% around town and 5-9% on highway. A bigger cam logically uses more fuel (even at cruise) because the valves are open longer.
Guys claiming better mpg on a big cam over their stock cam can likely put that down to a better tune, other mods, and more careful driving. Their big cam will cost mpg.
As stated pretty much anything will work. The LS6 cam is a big favorite. But having said that I remember the 700rwhp 4.8 running a cam out of a stroker. Also I personally know a turbo 4.8 running a MS3 on a 113 and several setups running the EPP FI cam (NA, Front and rear mount setups). You can also look at Speed Incs turbo cams.
