Any guesses what these dual springs might be?
I am hoping that someone might be able to identify these mystery dual springs that came on an engine that I recently purchased. There are no obvious identifications such as a colored stripe, etc. PAC 1521, Comp 9521, Patriot?
Thanks for the input... titanium would be a nice little bonus! If I would remove one of the springs and measure the height with a calipers, would this help determine the springs or do spring vendors normally not supply this info?
Inner springs are not gold. Here are the dimensions I pulled w/ a calipers:
Outer Spring:
OD: 1.2960"
Wire Diameter: 0.1735"
Inner Spring:
OD: 0.9480"
Wire DIamter: 0.1340"
Outer springs have a slight brown tinge, the picture above really doesn't show it. The inner springs are darker and closer to grey.
Outer Spring:
OD: 1.2960"
Inner Spring:
OD: 0.9480"
