What will my compression ratio be?
Old 02-02-2012, 03:51 AM
Ph.D. in HUBRIS
custm2500's Avatar
Default What will my compression ratio be?
My 408 previously had l92 heads with a standard 69cc chamber.
Can you tell me what my compression will be with my 317s. The chamber is 71.06 from what I can tell.
Thanks I will try to find my own calculations but wanted to ask the experts.
Old 02-02-2012, 04:23 AM
Ph.D. in HUBRIS
custm2500's Avatar
If my calculations are correct I will be loosing around .04:1 in compression.
Seems to not be right but what I did was found the cylinder volume got what % 2 cc would be and used that % to approximate the loss of compression.
I seem to be way off so if someone could confirm my numbers or my improper method it would be appreciated.
Old 02-02-2012, 05:08 AM
mark21742's Avatar
Look at WWW.wallaceracingcalcutators.com put in you numbers and it will give you your new compression.
