stroker 6.0 - offset ground crank
Old 03-19-2004, 06:57 AM
big358's Avatar
Default stroker 6.0 - offset ground crank
Anyone have info on an offset ground stock crank combination for the 6.0 engine?
I remember seeing posts in the past on a stroker setup getting a mild displacement increase based on an offset ground stock crank. Just don't recall what rod to use, what size journal the crank would have and what piston would be required.
Also, what shops have done offset grinds for ls1tech members?
Thanks
Someday soon I'll get my sig set up. Soon as I get back from the procrastinators' club meeting.
Old 03-19-2004, 08:13 AM
PSJ Wannabe & Attention Whore
BOO HOO BRIAN's Avatar
With the additional cost of offset grinding the crank as well as custom pistons, you are within $400.00 of a new eagle crank.
