Cam gear to use with Ls2 conversion cover?
You have to use an LS2 cam gear with the LS2 cover ,,,,,,,,the cam gear has no holes and has a raised section that goes 1/2 way around the outer part of the gear just inside the actual gear part . And if You have a pre-2005 engine and wiring harness and pcm You need to extend the cam sensor wires to reach to the front of the engine and while lengthening the wires switch the outside 2 wires for it to work .
