Milling Cylinder Heads for Torquer 3
I just picked up a used set of 243s, and I was wondering how much can I mill it and which gasket should I use to make a high compression setup for a torquer 3 cam. 11:1 or higher.
This will be my first cylinder head swap and I am concerned about clearances, I haven't found any threads that match this question.
I am also not going to be flycutting the pistons, as I'm too broke to do that.
