engine stall after cam
Old 03-21-2004, 12:29 PM
transamws6r's Avatar
Default engine stall after cam
I installed the hotcam in my 99 TA and after the install I started up the car and it kept stalling after a few seconds and it also runs really ruff, I adjusted the tension on the throttle body to make the car idle at 1000 rpms but sometimes it stalls when i put it into gear after warming up, is it necessary to drill a larger hole into the throttle body so it wouldnt run so ruff and stall? thanks, matt
Old 03-21-2004, 12:36 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Auto or manual?
Drilling the TB helps.
Use the search function to find out how much to drill out the TB.
A tune may be in order if the PCM doesn't learn the cam after a few hundred miles.
Old 03-21-2004, 04:44 PM
Cal
Cal's Avatar
You can run an extra 3 or 4 degrees of idle ignition timing (1200 rpm and below) to help smooth it out, but with the Hot Cam you will always have a somewhat rough idle.
