F1 cam (.591/569) questions...`
Will this cam work with Rev dual springs? Will the springs last a few seasons at that lift?
Will the 230/226 .591/.569 112lca be safe with stock pistons and new #241 heads/ 2.0" LS6 valves and a .035" mill job? Which valve am I nearing intererence with?
Last - do you think this cam will be a good choice with stage2 ported heads, LS6 intake, ported tb, Jethot lontubes, 4000 stall and 3.73 gear for a street car/pump gas? With a good tune of course...
Is it too big?
I want a low 11 sec reliable car.
Any opinionss or F1 users please chime in!!thanks
Is it too big?
Is it too big?
Is it too big?
I've been running this cam for close to 2 years with 918's. I'm not sure on the P to V clearance. I have 6.0L heads with a 2.02 and they clear. With tuning, the cam will be fine on the street. Your combo is similar to mine, except I have the PT4400.
If you are wanting a used one, I'll pull mine out. My new motor below is about done and I'll be selling it soon
