I have an Lq4 and Lq9, but dont know which to use.
Old 03-05-2012, 08:35 PM
texasstyle's Avatar
Default I have an Lq4 and Lq9, but dont know which to use.
Ok just want to know which to use. I have an 04 lq9 and a 05 lq4. I bought one and then the other was such a good deal i couldn't let it go.
I just need your opinion. One is going in the car and the other is going on craigslist. anyways my plan is to put ls6 cam on one for tx2k12 and then in the future add a turbo. I will eventually forge the bottom end. I know the lq4 is better for fi and the lq9 for n/a. but how much more hp will the lq9 make with the ls6 than the lq4.
Old 03-05-2012, 08:42 PM
Captain Double Post
BOBS99SS's Avatar
which one is in better shape?
Old 03-05-2012, 08:46 PM
Burken01's Avatar
the blocks are the same, only diffrence is the dished pistons in the lq4
Old 03-05-2012, 08:53 PM
texasstyle's Avatar
lq4 is 90kmiles
lq9 is 80kmiles
Both are in pretty good shape. Im also boosting it in the summer. I know the Lq4 is better for boost but how much better?
Old 03-05-2012, 08:57 PM
Burken01's Avatar
people run the lq4 in stock form alot because its lower compression already... so stock for stock the lq4 would be better for FI..
but once you forge them it doesnt matter because youll only probably reusing the block and crank and getting new everything else..
Old 03-05-2012, 09:06 PM
texasstyle's Avatar
So I should use the lq4, boost it, blow it and then forge it.
Old 03-05-2012, 09:13 PM
Burken01's Avatar
ha yeah that seems to be a good idea... it all depends on how much you want to spend.
It all comes down to cash money!! you can boost it stock and run it on a safe tune and mild boost for awhile..
or you can run higher boost and risk hurting the stock engine..
or forge it with rods, rod bolts, pistons, gapped rings for turbo, pinned main caps with arp studs..
its all up to you...
Quick Reply: I have an Lq4 and Lq9, but dont know which to use.
