Best heads EVER ?
Old 03-09-2012, 12:41 PM
f body lover's Avatar
Default Best heads EVER ?
Before you guys eat me on "search for it" I did a search but couldnt find a good answer Im about to ditch my 243 stage 2 patriot heads and MS3 for MS4 and cant decide on which heads I like the PRC 227 but some people told me look at Trick flow but I dont want to put a brand that used to be Ford number 1 on my Chevy the engine already has ARP head bolts,high volume oil pump,Mahle pistons and some other good stuff so what heads do you suggest?
Old 03-09-2012, 01:20 PM
JS01's Avatar
You can't really go wrong with the new AFR or TFS offerings for these engines. Check out MAST also.
Old 03-09-2012, 01:27 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
For a stock bore LS1 the PRC 227 head is the highest flowing current production 3.9" bore cylinder head I do believe. It offers you approx. 59-60cc chamber size potential while still clearing the MS camshafts.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 03-09-2012, 01:46 PM
Till now the PRC's on the top of my list
Old 03-09-2012, 01:53 PM
senicalj4579's Avatar
Tea/Tfs 215s is what I would do.
Old 03-09-2012, 02:47 PM
427LS7HCI's Avatar
Over the TFS 215s??
Old 03-09-2012, 03:45 PM
c5z16z's Avatar
this is interesting i was looking at trickflow 215cc but i started to hear alot of very good things about PRCs 227cc,,,,what set would be the way to go???
all my ls1 ls6 friends in houston are running afr 205cc but i have heard of better results from tfs215cc,,
would like to know wich to go with for stock cubed ls1 ls6
Old 03-09-2012, 03:48 PM
Rise of the Phoenix's Avatar
Why not the PRC 215's. If this is going to be a more street suited car, then I'd go with them over the PRC 227's.
Old 03-09-2012, 04:51 PM
badazz81z28's Avatar
Shoot me an PM if you are serious about selling your heads.
Old 03-09-2012, 06:42 PM
COPO9560's Avatar
The gains you will get from heads/cam switch again are not worth the money you will spend. You will spend thousands of dollars for what - 25 or maybe a few more rwhp - not worth the cash.
Save your money and increase displacement - put together a 408 or more and then a heads/cam change will be worth the effort.
A 100 shot of N2O is your best bargain with what you have now.
Old 03-09-2012, 06:50 PM
TVWilkes's Avatar
Originally Posted by 427LS7HCI
Over the TFS 215s??
Yes, even over the TFS 215's. The PRC 215 will outflow the TFS 215.
Old 03-09-2012, 06:57 PM
LilJayV10's Avatar
LS1Tech 10 Year
I thought this was the "Best head EVER" thread. Disregard.
Carry on.
Old 03-09-2012, 07:25 PM
Johnnystock's Avatar
Carry on.
yeah...confusing title. Best heads under 2500$..
Old 03-09-2012, 07:45 PM
I was looking at MAST heads they are awesome with 11 degree but out of my price range
Old 03-09-2012, 09:37 PM
JS01's Avatar
Well then you don't want the best heads ever.
Old 03-09-2012, 10:58 PM
garygnu's Avatar
consider getting a custom cam to get the most out of any great head.
Old 03-10-2012, 03:31 AM
BigRich954RR's Avatar
plus one
but TFS or the prc will do the same thing.
The ford brand things is dumb the TFS are a badass head there were people making 1600-1900rwhp with the tfs245
Old 03-10-2012, 04:09 AM
LS1ROPER's Avatar
Flow numbers are not everything! Look at the complete flow chart don't just look at peak numbers when choosing your heads. Ask yourself how long will you be in peak 700 range of the heads of your choice!
TFS!!!
Old 03-10-2012, 07:10 AM
ls1 down under's Avatar
I know in the states there are some great ls heads, but here in australia we have one guy who has nailed the ls heads. He supplies heads to the v8 supercar race teams as well as drag cars. His new lsx aspirated gto is currently doing 7.5 second 1/4 mile. All heads are cnc ported on a 5 axis cnc machine.
http://www.higginsraceheads.com.au/i..._graph_ls1.jpg
worth a look and everyone who has used these heads with cams ranging from baby thunder racing 220's up to bigger comp cam 240's have had fantastic results. Most Ls1's with 241 cast higgins heads and cam combination are pumping 300rwkw plus, Ls2 are over 320!
Old 03-10-2012, 07:27 AM
garcr4's Avatar
In the "Big Bang for the Buck" Category, I am more than pleased with our Advanced Induction 243's.
570 HP on the engine dyno at 6800 with a simple 11 to 1 383 road race motor with a 750 Holley carb. Have to raise the rev limit as the cam selected was still making power. Needs to be moved up 400-500 rpm.
This was also on a known very stingy engine dyno.
Quick Reply: Best heads EVER ?
