Oil pressure new pump not good
Old 03-15-2012, 06:36 PM
Uneverknow's Avatar
Default Oil pressure new pump not good
Its a slp oil pump not to say thats the problem anyways oil pressure when I start the car takes about 10 seconds to come off zero, but then it comes up to 40 and stays there then when I drive the car it runs below 40. But then when I start to run the rpms up 3k or more it drops pressure and the higher the rpms the more it drops.. Any thoughts.
Old 03-15-2012, 06:42 PM
poltergeist 02's Avatar
maybe a pinched o ring on the pick up tube?
Old 03-15-2012, 06:46 PM
why did you replace it in the first place?
Old 03-15-2012, 06:59 PM
Paul 75 L82's Avatar
Sounds like the o ring, it's a lot of work for such a little part.
Old 03-15-2012, 09:24 PM
Uneverknow's Avatar
Because I did a head cam intake swap figured s long as I was in there.
Old 03-15-2012, 10:11 PM
GeorgeD's Avatar
My LS1 did that, ended up being the o-ring. I had installed the SLP double roller chain and it comes with a spacer for the oil pump. I made the mistake of bolting up the pump and then the pickup tube. (this is in a Corvette so the F-bod may be different). The o-ring was seated diagonally and leaked. I had to tear it all down, replace the 0-ring, and made sure I installed the pickup end with the 0-ring first.
Old 03-15-2012, 10:24 PM
Uneverknow's Avatar
Thanks guys
Old 03-17-2012, 09:33 AM
Uneverknow's Avatar
Ok so my oil pressure is all over now. I was told to fill 6 more quartz if still oil pressure issue then not the o ring . I did this and now its dropping and building pressure at idel from zero to 30_40 any other thoughts bad pump?
Old 03-17-2012, 09:49 AM
redbird555's Avatar
wait are you saying you added 6 more quarts to an engine full of oil??
