compression test results before head swap
Old 03-17-2012, 11:16 PM
purple98haz28's Avatar
Default compression test results before head swap
car is a 98 z28 tr230 full bolt on with 153k. i am adding a set of stock 243 heads to the mix to replace the 806's and wanted to check compression before the head swap. here are my results...
1- 190 3-195 5-190 7-195
2- 195 4-190 6-180 8-180
so what do yall think? i am pretty pleased as this motor has 153k miles and i have read much worse numbers on here. factory spec is 200-210 right? i guess i am go for this headswap! just collecting a few more parts.Let me know what yall think of these numbers!!
Old 03-18-2012, 02:35 AM
SOMbitch's Avatar
I would say that is damn good for 150k motor. I wouldn't hesitate to drop some heads on that motor.
Old 03-18-2012, 09:58 AM
mark21742's Avatar
I agree, look pretty good to me
Old 03-18-2012, 10:47 AM
ls1kbush's Avatar
Those are good numbers and I would bet the lower numbers are probably from the heads being wore out.
I would atleast have the valvejob freshened up on your 243 heads. Shouldnt really cost more than 200 bucks if nothing needs repalced.
Old 03-18-2012, 03:08 PM
thanks all i was thinking they were pretty damn good for 153k miles!!! i have put the last 115k on the car and i change the oil every 3k so i can attest to what good service history does.When i put in my katech rod bolts the bottom end had a nice golden shine and crosshatching could still be seen in the cyls. the 243 heads i am putting on have only 25k miles so i would think the valve seats should be in good...i think. i may take them to the machine shop just to be tested and checked. so how much of a gain should i expect i've been hearing about 15-30 rwhp.
Old 03-18-2012, 05:09 PM
ls1kbush's Avatar
You should pick up atleast 10 to 15 but with a 3 angle valvejob done properly could make it closer to 20.
