LQ4 434 stroker?
LQ4 434 stroker?
According to this sticky:
My question: What is special about the LQ4 block vs an LQ9 or any other iron-block 6.0 for that matter that allows it to be bored .030? I thought they were the same blocks???
Does anyone have links to a 434 stroker build? Nothing turns up when I search "lq4 434."
J. J.
Custom Cubes:
If you are fortunate enough to get your hands on an LQ4 6.0L engine block, you can bore it .030-over and purchase a 4.250 Lunati stroker crankshaft to produce a 434ci. GenIII engine.
Add a set of GM Performance Parts ZO6 cyclinder heads (PN 12560801) or have the stock LS1 heads ported and you've got yourself a serious engine.
__________________
All information is taken from Chevy High Performance Magazine May 2002 editio
__________________
J. J.
That article is pretty old. Was it written right as the 6.0's started coming out? Hence, it would not have a reference for much more than the LQ4? It speaks of them as if they are rare but now days they're junk, everyone wants the LQ9's, LS2's, and 6.2L engines. I got a complete LQ4 for $200 and I really don't think there is anything unique about it as compared to say a LQ9.
Lunati lists cranks for them all the way up to 4.5"???
http://www.lunatipower.com/ProductGr...?id=161&cid=11
So does that mean a 460 stroker is possible now? I thought you had to have an LSx tall deck to get 454???
J. J.
J. J.
So that stick is in error then. That's kind of what I suspected. But if a .060 more is possible combined with a 4.125 crank that gets you 427 Cid. Put some L92 heads on it and that would be a sweet torquer!
J. J.
J. J.
