How to determine EXACTLY how much a set of heads has been milled?
Old 03-26-2004, 10:41 PM
SPANKY LS1's Avatar
Default How to determine EXACTLY how much a set of heads has been milled?
A buddy of mine picked up a set of used heads, and wants to verify how much they are milled so we can pick him out a cam. What is a good way to do this? I would assume that you could measure from the deck to one of the bolt surfaces, right? How close can we get, within .010 or so? Any other way to measure this? We're going to CC them, but the chambers have been ported on, so that won't tell us too much. Thanks, Shawn
Old 03-26-2004, 11:06 PM
Mike K.'s Avatar
measuring deck height is how I have always seen it done. You just have to compare it to a set of stock heads. Maybe someone has those measurements to give you ?
Old 03-27-2004, 12:03 AM
Richard@WCCH's Avatar
Measure the valve cover rail to the deck. It should measure 4.75" +or- .004" for a stock unmilled head. The most convienient place to measure with vernier calipers is at the ends of the head. Be sure that there aren't any nicks or burrs........
Good luck,
Richard
Old 03-27-2004, 07:50 AM
SPANKY LS1's Avatar
Forget to mention: They are 5.3 heads, is the above statement true for 5.3s also?
So, a stock head (5.3 too) should be 4.746"-4.754" right? Can anyone measure a stock unmilled 5.3 head to verify? I need it to be pretty exact. How close can we get with this method, within .005? Thanks, Shawn
Old 03-27-2004, 09:11 AM
I haven't got access to the factory blueprint for these heads, but the hundreds of them we've done over the years demonstrates the above info is correct for the 4.8l, 5.3l, 5.7l(&LS6) and 6.0l heads. I'm pretty sure the facory target size is 4.750" and the tolerance is + or - .003"-.004".
Richard
Old 03-27-2004, 09:47 AM
SPANKY LS1's Avatar
Thank you, Shawn
Old 03-27-2004, 07:41 PM
Old SStroker's Avatar
How about just cc'ing the chambers? That's the information you need to calculate CR which is essential to know if you are attempting to pick a cam that works with your combination.
Old 03-27-2004, 08:18 PM
SPANKY LS1's Avatar
We are going to CC the chambers, but we are wanting to know how much they are milled so we can determine if a given cam will fit, and that info is unavailable.
Old 03-27-2004, 10:15 PM
98_1LE's Avatar
I think it is better to check p-to-v clearance rather than "calculate" or "guestimate" it, at least if it is going to be close enough to even think about.
Old 03-27-2004, 10:19 PM
SPANKY LS1's Avatar
Right, but he wants to know if it *should* fit before he plunks down $400+ for a cam.
Quick Reply: How to determine EXACTLY how much a set of heads has been milled?
