unusual cylinder wall color 5.3L
Old 06-02-2012, 06:08 PM
DarkFox118's Avatar
Default unusual cylinder wall color 5.3L
forgive my ignorance, as I am still learning. (I like to learn by doing..)
this is my 2nd LSx teardown in the last 2 years. My last one was an LQ4.
I don't really understand what I'm seeing here?
This motor has 279k miles on it. I was told it was "running good" when the yard pulled it.
I plan to have it rebuilt, but I want to make sure my block/rotating assembly is good.
Old 06-02-2012, 07:01 PM
Gunslinger09's Avatar
Looks normal for an engine with that type of mileage on it. It looks a little like the oil wasn't changed enough though. You may need to have the crank turned down.
Old 06-02-2012, 07:03 PM
gjohnsonws6's Avatar
Looks normal. Just some varnish. Probably had cheap oil and fuel all its life.
Old 06-02-2012, 07:11 PM
DarkFox118's Avatar
Most certainly cheap fuel.
Glad it's not something to be concerned about!
My first look at it, it seemed green to me and I thought.. wth.. coolant leak? but coolant on these is normally red (and seemed to be when I dropped the water pump) so that kinda ruled that out.
No problem with having the crank turned, block honed, tanked, I plan to have a shop do this anyway.
Quick Reply: unusual cylinder wall color 5.3L
