Trunion upgrades or something else causeing this noise?
Old 06-07-2012, 10:44 AM
Cwarta's Avatar
Exclamation Trunion upgrades or something else causeing this noise?
Ok, i have another thread but im looking to get some input on JUST this issue. I originally measured and determined i need longer pushrods. I had comp magnum 7.4`s, and just installed comp 7.425`s. The valve train noise didnt change at all. It has about .060 preload on the lifters. A good friend told me that the trunion upgrades make alot of noise, could this be it? The cam is also on XER lobes. I dont like this sound, it sounds like its low on oil in a normal engine lol. But i checked, 30 psi @ idle and 40+ at anything above.
Cwarta's Avatar
Also with the new 7.425`s im @ .060 preload on the lifters.
Old 06-07-2012, 03:20 PM
3rdCoastPowerSports's Avatar
I'm not hearing the problem, sounds fine. did you disconnect your serp belt to make sure the noise you think your hearing is not coming from a worn out bearing on an accessory?
Old 06-07-2012, 07:24 PM
Cwarta's Avatar
Ya, its deffinatley upper valve train.
Old 06-07-2012, 07:47 PM
99Bluz28's Avatar
I just went from a noisy .060" preload to .085" preload, it did quiet it down a noticeable amount.
Old 06-08-2012, 10:08 AM
LS1Tech Premium Sponsor
Sales3@Texas-Speed's Avatar
It may be the video, but I am not hearing anything strange either. Typically the trunion upgrade kits should not produce more noise. Also I assume that you are running stock lifters, if so you are within spec of recommended preload.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old 06-08-2012, 10:22 AM
Tainted's Avatar
I think you hear the infamous piston slap with a dash of noisy *** lsx valvetrain
Quick Reply: Trunion upgrades or something else causeing this noise?
