TREX cam and stock heads P to V clearance issues?
Old 04-01-2004, 01:21 PM
BIGBOS's Avatar
Default TREX cam and stock heads P to V clearance issues?
A friend of mine is putting the Trex cam in his 346 motor, he will be using stock heads, will there be any P to V clearance issues w/this setup?
Old 04-01-2004, 01:28 PM
Motorboater
SilverGhost's Avatar
if the heads are bone stock never been off the motor then no problems, it'll be fine
Old 04-01-2004, 01:42 PM
BIGBOS's Avatar
yea, thats the case
Thunder still told him to check, but that would be a pain in the *** to pull the heads and use the clay process when there is no need to
Old 04-01-2004, 01:49 PM
Motorboater
i talked to Jason out there for awhile out of curiosity on that cam and he said you better check when using any aftermarket head..even if it hasnt' been milled because different vendors do their valve jobs in different ways and that can effect the PTV potentially enough to cause a problem.
everything i've see/heard/read you have nothign to worry about if the heads have never been off
Old 04-01-2004, 03:28 PM
Josh's Avatar
I agree with what these guys have said. If your heads have never even been off the car, you shouldn't have any problems. Just make extra super sure that the dots on the timing gears are lined up.
Josh
Old 04-01-2004, 04:26 PM
smithsc's Avatar
You think it would make any difference if we were talking about LS6 heads instead of LS1?
Just bought a Trex off Spanky for my 02 Z06 and don't want any surprises here!!
Steve
Old 04-01-2004, 05:02 PM
AustinL911's Avatar
I pulled my stock heads off the car because I was going to go with aftermarket, but decided to stick with the stockers for awhile. I'm using a Victor Reinz (NAPA) graphite gasket. PTV should still be alright, correct? Even if the head gasket was a different thickness, I wouldn't think it would change it that much. Opinions?
Old 04-01-2004, 05:06 PM
SPANKY LS1's Avatar
Austin- Make sure before you swap gaskets. GM graphite gaskets are ~.054 compressed, and MLS are ~.060. TR only had .070 intake and .090 exhaust with the thicker MLS gaskets. (For reference, .080/.100 is generally accepted "minimum" clearance requirement, so its being pushed already). Now, if that gasket is only .05-.10 thinner than the stock MLS gasket, you're cutting an already tight clearance down further. Be careful, and make sure that that gasket is at least as thick as the stocker, with this combo there is no extra room to play with, IMO.
Shawn
Old 04-01-2004, 05:58 PM
chrdij's Avatar
Valve jobs can cause problems with PTV? The reason I ask, I am going to have MTI place a set of over sized valves in by manley (2.02, 1.60) on a set of ported, unmilled ls1 heads. I plan on using the stock GM gaskets, does anyone think I will run into any problems with this cam ?
Old 04-01-2004, 08:11 PM
SPANKY LS1's Avatar
Usually a valve job will give you more P to V clearance, because the seats are cut, and the valve sits "deeper" in the seat, further away from the piston. If you are having a valvejob, machine shops can "sink" the valves in the seat for more P to V clearance, however, too much will negatively affect flow. My old S2.5 Absolute Speed 5.3s had the valves sunk ~.015. Good luck, Shawn
Old 04-02-2004, 02:08 AM
I can shift faster than you.
Jason99T/A's Avatar
Shawn, all of our PtV testing was with the .053" compressed graphite, not the '02 MLS gasket.
Jason
Old 04-02-2004, 03:53 AM
KMStevens's Avatar
I am using a comp 242/248 .610/.615 110 XE-R in my car, checked the clearance and this is what I found, the marks are hard to see but it touched. double checked everything again to make sure it was lined up right dot to dot etc and didnt make a difference. looks like Im gonna be flycutting.
Attached Thumbnails TREX cam and stock heads P to V clearance issues?-dsc00703-1.jpg
Old 04-02-2004, 03:55 AM
KMStevens's Avatar
well the picture didnt show up, but the valves did in fact hit. I'll see if i can upload it from somewhere else.
Old 04-02-2004, 04:38 AM
SPANKY LS1's Avatar
Jason
Sorry, I misread. So, with the thicker MLS gasket, you'd have about .077/.097. My point was that it would fit, but there was no room for any less clearance, such as milling, thinner gasket, etc.
Shawn
Quick Reply: TREX cam and stock heads P to V clearance issues?
