Preparing for a cam swap. Am I missing anything?
I recently got a good deal on the GMPP Hot Cam from a friend that had it on a shelf collecting dust. I am getting things together for it's install and wanted to make sure I have everything needed before getting started. This is a list of what I have and other stuff I will be getting soon. Is there anything that I am missing? This will be on the stock 853 heads.
Parts I have:
GMPP "HOT" Cam - 12480033
Front cover gasket - 12558013
Cank seal - 12561244
Water pump gaskets x2 - 12559271
New crank bolt - 12557840
Valve cover gasket x2 - 12560696
LS6 spring seat x16 - 12565118
LS6 spring lock x16 - doesn't have a part # on them, 10166345 I think?
LS6 spring (Blue) x16 - 12565117
Parts I need to get:
Valve stem seal set (intake) - 12533586
Valve stem seal set (exhaust) - 12457652
Spring retainers x16 - 10166344
LS2 timing chain - 12586482
Ported LS6 oil pump and new o-ring
3 arm pulley puller
Valve spring compressor tool
Flywheel locking tool
KD tools 901 air hold fittings
KD tools 2992 air hold extension hose
5/16" dowels to hold the lifters
Is there anything other than the obvious fluids and sealants that needs to be added to the list? Thanks!
Parts I have:
3 arm pulley puller
I'll check that kit out. Thanks for the heads up on it.
Wouldn't there be some noticeable noise coming from the valve train if one was bent? I can't deny the wisdom and piece of mind that would come from replacing them, I was trying to do the swap on the cheap WS6store has a set of stock sized Manley chromemoly rods for $100 right now so I guess that I'll add that to my list.
