Short-notice install
Folks:
Can someone give me a ballpark figure on how much an install of the following items should/could run me for my '98 LS1- (please don't say I can do it myself. absolutely not an option at the moment)
comp cams chrome moly pushrods
comp cams pro magnum lifters
slp dbl rolr timing chain
comp cams 921 dual spring kit (#26921)
Thanks.
Thanks.
Folks:
Thanks.
Thanks.
why no cam swap ?why are you replacing the lifters ?the heads will need to come off for a lifter swap.how many miles on the engine ? get a ls2 timing chain from TSP.a good shop that knows ls motors will need about 8 hrs to do the job.you probably looking at $800-1000.
The standard flat rate allowance to remove and replace the heads is 16.5 hours including a valve job. The allowance for replacing the timing chain is 10.4 hours. Given the degree of overlap in the two processes, I would expect labor charges of no less than 20 hours. Hourly rates, of course, vary between shops and by geographic location.
Cam not an option since the car is my daily, and can't risk perm check engine light issues. Everyone I knew/heard of who did illegal smogs either had the shops closed, or have elected to no longer do these smogs. Car has about 140K miles and b/c of other life expenses, and can't afford a $10K crate engine upgrade at this time.
Unless you know of a reason to change that stuff, leave it alone as is. Dont need put double springs on astock cam. It will only hurt performance. If you're just looking to replace wearing parts, get a LS2 timing chain and a LS6 oil pump (the il pump is more important than any of the other things anyway).
