keep the tfs 215 or go bigger?
Old 07-06-2012, 11:20 AM
dferg99's Avatar
Default keep the tfs 215 or go bigger?
Hey guys I just had a 408 built for spray, and was wondering will my tfs 215 perform well or should I sell them and get some 225's or bigger. I plan on spraying a 300 shot at this motor. Compression now is a little over 11 to 1. The tfs 215 have 64cc chambers straight out the box. The cam is 25x / 26x range. How much am I leaving on the table with these heads? Maybe I should see how it runs then decide lol.
Old 07-06-2012, 03:58 PM
30th t/a's Avatar
Here is a 408 with TFS 215's
https://ls1tech.com/forums/dynamomet...8-results.html
Old 07-06-2012, 04:45 PM
djfury05's Avatar
TFS 235's or bigger
Old 07-07-2012, 02:44 PM
chrs1313's Avatar
Originally Posted by djfury05
TFS 235's or bigger
Agreed all the way...
Need more head to get the most out of the setup
Old 07-07-2012, 07:46 PM
Sprayed1998's Avatar
My 403 made just over 500rwhp with tfs 215's and a smaller stroker cam. Have since added 1 7/8 headers, 3" exhaust and an electric water pump. Looking for 525 or so. Makes really good low end power compared to the bigger heads, just depends on what you like.
Old 07-07-2012, 09:18 PM
wildcamaro's Avatar
Go big or go home lol. Selling afrs is as easy as it gets
Old 07-07-2012, 09:38 PM
My6speedZ's Avatar
You can also have them opened up by TEA if you wanted. That 408 post doesn't seem to optimized. I imagine that those 1 3/4 headers are hurting that set-up.
LS2 bait has some 215's on his LS3 416 that were opened up for the bore and he has a strong set-up so it can be done.
Old 07-07-2012, 09:39 PM
oldguy99Z's Avatar
I agree with the guys saying go bigger like 235's and if your gonna spray it alot check into the nitrous exhaust port that TEA does.
Old 07-07-2012, 10:22 PM
reeperz28's Avatar
Seen really good results with 215's on larger cube engines but they will sell themselves of you wanted to go bigger.
Old 07-08-2012, 12:39 AM
dferg99's Avatar
Yeah the more I think about it the 215's are better suited for a smaller cubed motor. Anybody wanna swap some almost new tfs 215 for some 235's lol
My set up thus far 104 lid, 100 maf, fast 102, 1 7/8 headers, cut out, tfs 215 (unmilled). The cam is gonna be in the 24x / 25x range. I think she should breath good with what I have and not choke the motor up top?
Old 07-08-2012, 02:33 AM
mark21742's Avatar
With the can your running I would definately get your compression up higher....I'm running 12.5:1 on mine and have no problems running 92-93 pump gas
Old 07-08-2012, 04:32 AM
dferg99's Avatar
Really, nice to know that. My engine builder told me any higher and I wouldnt be able to run on pump gas. I thought about milling the heads to bump up the compression, but wasnt sure if that would hurt me since im spraying a large shot. Don't want to compromise the thickness of the deck. Any and all input would be greatly appreciated.
Old 07-08-2012, 08:27 AM
My6speedZ's Avatar
My cylinder heads are milled to 59cc which gives me a compression ration of 11.5:1.
I have PM'd Brian Tooley a few times talking with him about a combo I want to put together when I am ready to pull the trigger which will most likely be a 416 using my 215's I have now and having them worked over a little bit with a custom cam.
As far as deck thickness isn't it something like .006 or .008 per CC?
Old 07-08-2012, 03:29 PM
dferg99's Avatar
Yeah you are right about the thickness. I think with the right cam, and head work these combos will be very stout. Maybe I will just mill my heads and see what type of numbers she makes.
Old 07-08-2012, 05:28 PM
chrs1313's Avatar
Dcr is what you want to be concerned with not scr...
I would keep it 8.8:1 or lower, also no timing over 28* helps too, tighter quench, optimized good chambers...it all is important to reduce knock
Old 07-09-2012, 08:13 AM
dferg99's Avatar
So Chris are you suggesting dont raise the compression anymore by milling the heads, keep it a little over 11 to 1
Old 07-09-2012, 10:06 AM
mark21742's Avatar
Yup exactly. I'm sitting at 8.22:1dcr.
Lots of people just don't think a big cam drops dcr that low, so they say "stay at 11:1" or whatever without thinking about how low the dcr or cranking psi will be after dropping in a big cam with a late intake calves closing point
Old 07-09-2012, 10:31 AM
BrianSF-GA's Avatar
Here is another stroker example with TFS 215's only it's a 402 ....
The TFS 215's flowed ...
0.100 59.6 68.3
0.200 121.9 139.8
0.300 186.7 218.5
0.400 231.4 270.9
0.500 254.2 304.3
0.550 260.2 314.8
0.600 266.1 321.8
Before the comments ... yep ... the 1-3/4's and the 215's are probably hurting power in the higher rpms, but, for now, I am concentrating on suspension and hooking it before looking to add power.
FYI, this curve was through the 10-bolt with 4.10's on 10-spokes with 275's ... !
Old 07-09-2012, 05:42 PM
My6speedZ's Avatar
0.100 59.6 68.3
0.200 121.9 139.8
0.300 186.7 218.5
0.400 231.4 270.9
0.500 254.2 304.3
0.550 260.2 314.8
0.600 266.1 321.8
Always liked your combo, I have the same cam and would imagine that on a 402 its pretty tame.
Old 07-09-2012, 05:51 PM
30th t/a's Avatar
0.100 59.6 68.3
0.200 121.9 139.8
0.300 186.7 218.5
0.400 231.4 270.9
0.500 254.2 304.3
0.550 260.2 314.8
0.600 266.1 321.8
Those power curves are beautiful for a street car! That torque must feel unreal!
Quick Reply: keep the tfs 215 or go bigger?
