El Toro cam vs torquer v2... Owners post up info
Old 07-16-2012, 05:50 PM
smileyou's Avatar
Default El Toro cam vs torquer v2... Owners post up info
I was looking at the cams variances between each other. I want to have high peak hp while still retaining alot of down low torque. I dont want the cam to be a slug downlow or drop off uptop badly.
El toro-
230/234 .612/.598 111+3 LSA
xfi/xer lobes
Torquer v2.
232/234 .595"/.598" 112+4 LSA
Which would be better for a 2001 camaro ss with tsp true duals dumped, slp lid,ported stock tb,ls6 intake, slp underdrive pulley, pacesetter lt's , 3 inch x pipe, k&n filter, m6 with stock gears.( Stock 241's for now)
Im wanting to stay away from double springs and short spring life. I am looking to spray a 100 shot in the next few months. I also expect to pick up atleast some 243's in the next 6 months. Which cam would work best?
Old 07-16-2012, 05:59 PM
bigantws6's Avatar
That's pred z cam he will chime in for u good guy and knows his **** when comes dwn to cam I have the el toro cam gona be up forsale
Old 07-16-2012, 06:02 PM
smileyou's Avatar
Why are you getting rid of it?
Old 07-16-2012, 06:25 PM
My6speedZ's Avatar
For a good street cam, I think you might really like the VRX4 cam or maybe the VRX5 (although they suggest a double spring with that cam).
The vrx4 will give you a really nice torque curve. You will want that if your not planning on changing the gear anytime soon. You don't want to get a huge cam that needs 4.10 or 4.30 gears and have to sink money into the 10-bolt (especially with a stick car, because its already weak enough) just to enjoy the car. Trust me I've been there and done the same thing and wasted the money.
Old 07-16-2012, 06:43 PM
bigantws6's Avatar
Cause of PTv clearance issue so going with a little smaller cam
Old 07-16-2012, 07:38 PM
MyFirstLS1's Avatar
I'm currently running the v2 with dual springs, wouldn't go any other way just incase of failure it won't drop a valve.
As far as low end torque its still throws you back, according to the graph, not sure if it was 3rd or 4th but peak torque 393rwtq @ 4500rpm and 323rwtq @ 3000rpm. Peak rwhp was 411 @ 6400rpm
I can't say anything about the other cam, I have no regrets with this cam just wish I could have put on cnc'd heads FAST intake. Maybe a sligtly lower LSA for a choppier idle.
Running 243's /w a ls6 intake, resurfaced and stock thickness headgaskets. I also daily drive this car if it means anything to you. So far I am hovering just under 20k miles on this set up
Old 07-16-2012, 08:46 PM
PREDATOR-Z's Avatar
El toro-
xfi/xer lobes
Torquer v2.
They are similar both in size and valve events.
The 111 LSA has 2 more degree overlap so theoretically should put out a few extra hp (more lift as well on intake). But that is a a minimal few.
Old 07-16-2012, 08:54 PM
intenseblue's Avatar
When did the el torro move from a single pattern duration to a four degree split?
Old 07-16-2012, 09:00 PM
PREDATOR-Z's Avatar
It is just a derivative due to different supporting mods. IIRC the 230/234 might have been for nitrous application or something like that.
Look at my sig, that is another derivative. The original El toro is
230/230 .612/.592 111+2 LSA
But once it is cut, the XFI intake lobe always come out as 232, so in reality it is a 232/230 .612/.592 111+2 LSA which makes it a Reverse split.
Old 07-16-2012, 09:29 PM
Gotcha, I knew the specs on the original. I thought the OP might have read something wrong and posted the wrong specs for the El Torro camshaft, then I seen your reply with no mention of the exhaust lobe differences and thought I might have missed a revision in the past "x" amount of days,weeks,months etc. Thanks for the quick response.
Didn't mean to throw the thread off if I did.
Old 07-16-2012, 10:58 PM
smileyou's Avatar
Anyone know the mpg expectancy for the tv2?? I dont want to be under 20mpg becuase of a monsterous cam. Ifso ill just have to settle for the 228r or the 230r
Old 07-16-2012, 11:39 PM
99Bluz28's Avatar
Any where from a 227-232 intake, and 228-234 exhaust lobe, and 109-111lsa
If your looking at the TQR v.2 go with the 111 or even a 110 lsa.
Old 07-17-2012, 07:25 AM
LS1HIGHLIFE's Avatar
I run the v.2 with 5.3 heads and average 15.5mpg playing around and city driving. On the highway I've seen 25-26mpg. It's a nice cam, but I wish it had a better thump.
Old 07-17-2012, 07:35 AM
Ethan[ws6]'s Avatar
Made the mistake of running beehive springs with that cam. Paid the price after 8k miles
I was on this same setup. Made 430rwhp and had great driveability!
PREDATOR-Z's Avatar
What LSA on the cam?
Old 07-17-2012, 10:09 AM
It's a 112
Old 07-17-2012, 10:38 AM
smileyou's Avatar
It's a 112
Do you wish you went 111 lsa?
I just found out my 241's have double springs in them... previously left from the last owner. So im pretty sure im going to the tv2 112+4 lsa.... or should I go 111?
I also dd this car 45 miles a day.
Old 07-17-2012, 10:53 AM
thunderstruck507's Avatar
You should still have the springs checked. They are a wear item and could still cause problems with the new cam...potentially destroying it.
Old 07-17-2012, 11:08 AM
PREDATOR-Z's Avatar
Yes i agree with Thunderstruck507, you should have them all pressure tested.
Old 07-17-2012, 11:34 AM
smileyou's Avatar
Would I get that done at a machine shop?
The last owner said there wasnt that many miles on the comp cam setup... and before it was sold to me he had swapped it out for the stock cam.. He wasnt running cammed long he said... how much would it cost to check to see if they are still in spec, and where would i do that.
Quick Reply: El Toro cam vs torquer v2... Owners post up info
