Oil Pump O Ring
Oil Pump O Ring
Will the o-ring for the oil pickup tube that goes into the oil pump deteriorate on it own or would it only be damaged from the pickup tube being removed and not reinstalled properly? I ask because my dad just bought a 05 Envoy with a 5.3 and the oil pressure is nothing at idle and has a slight knock(bought knowing this) yet the oil pressure will rise to 40#'s with any amount of throttle. He was told the o-ring was known to go bad over time but I was under the impression that it had to be tampered with and reinstalled improperly to mess it up. Just trying to figure this out before we go through the trouble of replacing the o-ring and not solving the problem.
Those o-rings generally, depending on what they're made of, black, Viton ????last 10 years or longer before dry rot causes them to crack and that is in Phx, Az where it gets a little hot .
