Taking carbon off cylinders without removing them
Old Jul 23, 2012 | 12:27 PM
rumblebox's Avatar
Default Taking carbon off cylinders without removing them
I can use a plastic die grinder wheel on them and remove the crap easily, but I'm wondering if it's a big deal for the particles to get in the rings of if it will just burn out or get cleaned out with the first oil change.
Thoughts?
Old Jul 23, 2012 | 03:02 PM
01ssreda4's Avatar
Bring em up to the top. Hose em with brake parts cleaner, wipe, repeat until clean. Doesn't take long.
Old Jul 23, 2012 | 03:31 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Brake cleaner or Berryman's B12 will do the trick!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jul 23, 2012 | 05:04 PM
wildcamaro's Avatar
I used the plastic discs you are talking about and they worked great! Yellow takes off the tough stuff and white is the finishing disc
Old Jul 23, 2012 | 05:22 PM
GMtechmatt's Avatar
you wanna know a good idea Gm upper engine service spray it through the throttle body let it sit for 20-30min thats the vehicle and water the carbon burn out!
Old Jul 23, 2012 | 06:35 PM
gMAG's Avatar
GM Matt...can you please repeat your comment, with punctuation?
I'm not entirely sure what you've said.
Thanks.
Old Jul 24, 2012 | 08:32 PM
gMAG's Avatar
Got it, Matt.
I did a search on Yahoo.
Old Jul 24, 2012 | 08:34 PM
rumblebox's Avatar
b12 works ok with the engine still assembled, but it wont compare to manually removing all the carbon.
Old Jul 24, 2012 | 08:51 PM
Jeff Smith's Avatar
Good Inform..sub.......
Old Jul 24, 2012 | 09:53 PM
slowsol95's Avatar
I just did this, brake clean and a scotch brite works great. Just bring the piston up to the top of the cylinder, spray with brake clean, light scrub with a scotch brite, and either use a shop vac or some rags to clean up the mess.
Old Jul 25, 2012 | 06:50 PM
gMAG's Avatar
I used Citra-solv with a scotch-brite. Dab the inner cylinder & exhaust ports with a wet Citra-solv-ed paper towel. Let sit....then scotch-brite & wipe clean.
It all came off like hot butter.
Old Jul 25, 2012 | 06:56 PM
JUSTINSWS6's Avatar
Dont use oven cleaner! Saw a guy on here use it before
