what big cams fit with PP LS6 heads 59cc
what big cams fit with PP LS6 heads 59cc? Because they arent milled, what kind of big cams will fit without flycuting? G5X2 (232/240), G5X3 (?????), TSP Magic Stick v.1 (238/242), Magic Stick v.2 (239/244), TR "Trex" (242/248). what "big" cams are people using with these heads?
I know the X2 and the X3 on a 114 will fit. I do believe the Magik sticks were being designed to fit also. The t-rex won't because it maxes out the clearence on stock heads, so any valves bigger than stock will cause clearence problems. If you go with a 2.05 valve over the 2.02, your choices get even smaller.
Originally Posted by jtz28
Go with the AMS 239/236 Cam, its what I run. I put down 420/436 through my 3.42's (A4)
I gained a crapload of power over the old TR224 cam I used to run.
those numbers are locked right?
