whats the best head castings to look for?
theres so many castng numbers to choose from,can someone please give me a list of LS head casting numbers that are popular,thanks!
LS1Tech Premium Sponsor
It depends on the short-block you intend to run. If it's an LS1/LS6 block, one of if not the best GM castings to run is the LS2/LS6 casting number 799 or 243. Of course when you get into a 4.0"+ bore you can start running the LS3/L92 head combos and that opens numerous other options.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Then the 243 and 799 castings would be the two best to look for for an NA or nitrous setup!
As a note, you will have to switch over to the center-bolt valve covers and coil brackets if/when you find some of these to run.
__________________
The 243's have a sodium filled (lighter weight) exhaust valves, whereas the 799's were a regular solid valve. If they are in good shape and you got them for under $500, you did alright. If you got them for under $400, you did very well. Under $300, WAY TO GO!!
__________________
Ever back to backed the 5.3L heads with an LS6? Stock for stock, and apples to apples, ported vs ported, the LS6's make better peak and average power.
__________________
Agreed, the C5R/DR stuff is awesome, but out of reach (availability and total involved price) for the average guy starting a new thread on here looking for advice.
__________________
Indeed, it slipped my mind but you are correct! Thanks.
__________________
what they want to charge is a good price.
I think retail bad *** guys guys charge $250 up to 350, that knows what there doing on the head, and valves. And would like to blend it for 1-2hours labor 75-$200.
Or normal rebuild shops "3 angle" VJ for $200, with a generic cutter they bang out 90% of the head the come in the door with. And their upgrade is to port the head for $500-$800.
The rebuild shops VJ will be up or DOWN 5whp, (10-20whp over stock LS1 heads, remember 799/243 will gain 15-20 untouched) and the full port will up another 10. The good VJ unported will be 20-30, I hear some 40+ unported blended
