Need suggestions for gaskets.
Old 09-06-2012, 12:44 AM
Dynomitefries's Avatar
Default Need suggestions for gaskets.
Hi all, I'm currently building a 1998 ls1 with 243 ls6 heads. I'm having trouble finding a gasket set for it. What i'd really like to have is a full gasket set from the oil pan and up. I've read that the original head gaskets are really good, but if not i'd like to get something really reliable. The cylinders are bored to the max at 3.908". Any help or feedback would be fantastic. Thanks!
Old 09-06-2012, 07:39 AM
conan's Avatar
Give Texas speed a call they put together a entire engine gasket/seal/bolt "kit" for me when I built my engine. http://www.texas-speed.com/default.aspx
Old 09-06-2012, 09:20 AM
MT0911's Avatar
^ This
It's much more convienent than peicing everything together yourself plus it cost about the same. I've pieced together gasket/seal/bolt "kits" and I've also ordered through Texas Speed on different builds. Texas Speed will get you covered
Old 09-06-2012, 09:32 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
For a complete set, it is our Deluxe Heads/cam gaskets kit (select the options you want/need in the pull down menus):
http://www.texas-speed.com/p-194-del...asket-kit.aspx
plus these (EGR and AIR gaskets excluded)
http://www.texas-speed.com/p-2268-gm...lant-seal.aspx
http://www.texas-speed.com/p-215-gm-...an-gasket.aspx
http://www.texas-speed.com/p-212-gm-...er-gasket.aspx
http://www.texas-speed.com/p-217-gm-...main-seal.aspx
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 09-06-2012, 07:25 PM
Hey thanks for the help guys, i'll definitely give them a call!
Quick Reply: Need suggestions for gaskets.
