replacing Barbell with welch plugs
Is there any reason that won't work? All the bearings in the motor looked good.
Thanks,, Larry
Here's another perspective on the inclusion of the 'newer' design of the barbell. It restricts oil flow up top.
https://ls1tech.com/forums/generatio...d-z06-etc.html
As a side-note, I had the orig design barbell. After toasting all bearings, & crank, I found that the barbell had popped out. The newer design has a longer back end to the plug, which is better held in place (keeps it from coming out) by the back cover.
Larry
I agree with your comment. There is only one oil line at the point of the diverter.
The OP in the redirect chose the wrong words to describe the action of the later plug.
Sorry I wasn't more clear.
Glenn
Without the barbell, the oil would shoot past the oil filter and fill the rear case. It was a simple solution GM came up with to keep the block machining simple.
The one below doesn't include the barbell, which made me think that, while the barbell was pushed in to the back of the galley, it didn't reach far enough to separate the in & out of the oil filter. In this scenario, the in & out oil passages would have to be separated by some other means.
Concerning the OP's original question, I don't see how freeze plugs can be used in place of the barbell. A freeze plug would plug the hole at the back of the block but would not internally split the oil path to divert it through the filter first.
