Max cam lift standard gen3
Old 09-21-2012, 05:40 AM
Glenno108's Avatar
Default Max cam lift standard gen3
What is the max cam lift on a standard gen3 better way to find out is ask this way
Old 09-21-2012, 08:50 AM
moeZ28's Avatar
Are you talking stock valve springs or just as big as you can go in general? Lift has less to do with piston to valve clearance than duration and LSA.
Old 09-21-2012, 05:07 PM
Glenno108's Avatar
Na not stock valve springs, 135+lbs .625 Mac lift springs I have a 236/242 .612 .612 113 and the springs for it but someone has turned around and said that cam won't fit, not I'm unsure if I wanna put it in now incase have to pull all out again
Old 09-21-2012, 05:19 PM
moeZ28's Avatar
It would fit stock, unmilled heads but it will be close...those specs look like a RAPTR cam but cut on a 113 LSA...if you have milled your heads any, i would say you would need to flycut your pistons to make it fit.
Old 09-21-2012, 05:21 PM
PREDATOR-Z's Avatar
lift has nothing to do with PTVC.
Think about it; when does max lift occur in the stroke?
Old 09-21-2012, 09:17 PM
Glenno108's Avatar
The intake valve closes long before TDC I was just unsure about the exhaust valve just thinking that must close alot closer to TDC
Old 09-22-2012, 07:56 AM
studderin's Avatar
its not at max lift as said.
most of the time its around 8-12* form TDC min PtV chasing each other
Old 09-22-2012, 01:45 PM
PREDATOR-Z's Avatar
Yes, Max lift is close to or at BDC (piston is furthest away from valves)
Old 09-22-2014, 03:40 PM
lsexpress's Avatar
.650 I would guess
Old 09-22-2014, 04:15 PM
Violence.z06's Avatar
The duration is what you should be concerned with not the lift. i also wonder myself how far you can go duration wise before they hit. from what i see 240 @.50 seems pretty safe
Old 09-22-2014, 04:41 PM
svede1212's Avatar
I don't think it has any hard set answer. After you get up in that range you should check. Other things like RPM or a stretched timing chain changes valve events.
Quick Reply: Max cam lift standard gen3
