melling10295 or 10296
have a 383 with low oil pressure.. i believe my original engine guy had the clearences too loose bc another ls i found out he built has same low oil pressure as me.. which is the high pressure pump that i should use on my 383? going to be buying a new one when i pull the motor to let cartek redo the bearings
LS1Tech Premium Sponsor
Unfortunately, putting a different pump on an engine with loose clearances is like a band-aid on a bullet hole Between the two, if I had to try it, I'd go 10295 with the higher pressure spring....but the right answer is to get the right bearings in there for sure!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Gotcha! With better clearances, the 10295 will still work very well, but I'd run the lighter spring.
__________________
