Is the LS3 head the same as a L92 head?
Yes, they are compatible. The castings are the same. The intake valves are the main difference, with the ls3's being a tad lighter.
Wow! 20 grams. I didn't realize there was a 20 gram difference. Have you verified this number yourself, or were you told this? That is a lot of weight on a valve.
The casting is the same # are different. I have had two sets of l92 and both had different # on them. I bought a set of replacement ls3.
I did weigh the valves 109 to 89.
Lighter the valve less spring to control it. I turn mine 7500 with the lunati spring kit and have not had any issues.
Tim
Tim
Tim
Tim
L92 has a MUCH heavier valve and needs a MUCH less aggressive lobe to control it.
