Timing chain tensioner/dampener solutions?
Old 10-26-2012, 09:05 AM
ckpitt55's Avatar
Default Timing chain tensioner/dampener solutions?
this is my first time working on an LS1 motor, and noticed that there was no timing chain tensioner on the motor- though my block does have the mounting holes for it. the fact that a tensioner was absent really surprised me.
that being said, i've done some reading and some research. i'm upgrading to an ls2 timing chain and would like to also add a dampener and/or tensioner to avoid the off-throttle chain whip problems guys have mentioned on here.
from what ive gathered: the LS1 dampener is NLA (or incredibly expensive), the LS2 dampener has a different hole spacing, and guys seem to have problems with the LS3 tensioner/dampener tearing itself apart.
are there any aftermarket tensioner/dampener options? would one from an LS7 fit or would i run into problems with oil pump/timing cover clearance?
Old 10-26-2012, 10:20 AM
427's Avatar
One solution bolts a plate on the cam retaining plate bolts and drops down. I believe it is Jegs that sells it.
Kurt
Old 10-26-2012, 11:53 AM
themealonwheels's Avatar
I installed an adapted LS2 dampener on my LM4, you can find it on eBay if you search ls1 timing chain dampener. Fit perfectly and for about $65, it's nice insurance.
Old 10-26-2012, 12:05 PM
Undertow74's Avatar
trick flow sells a adapter kit that bolts to the cam retainer. got it on mine, no issues and nice piece
Old 10-26-2012, 12:29 PM
ckpitt55's Avatar
right on, thank you.
Old 10-26-2012, 03:02 PM
pairof69s's Avatar
yep just bought mine....good piece of mind, Ls2 timing set just has to much slack for my liking.
Quick Reply: Timing chain tensioner/dampener solutions?
