Patriot Extreme Valve Springs, stock cam?
Old 11-15-2012, 10:14 PM
chon79's Avatar
Default Patriot Extreme Valve Springs, stock cam?
Hey guys, would running the stock cam with Patriot Extreme valve springs and hardened pushrods cause any issues? I've met a couple of guys doing this on their cars (bolt-ons, nitrous) with no problems, but wasn't sure if this would cause any long term damage.
Old 11-15-2012, 10:41 PM
bluenightmare's Avatar
I did the same thing in my engine and I have a NASTY valve train tapping until the engine warms up. if it is cold enough it sounds like a diesel. But so far when she is warmed up it runs fine
Old 11-16-2012, 02:57 AM
Jontall's Avatar
Patriot's Gold springs would work great without all the extra stress the Extreme springs will cause.
Old 11-16-2012, 08:19 AM
J Glen's Avatar
Why are you using those springs on a stock cam? I am guessing you are planning a cam swap in the future? If not buy a different set of springs.
Old 11-16-2012, 09:08 AM
chon79's Avatar
We are putting a car back together and found a motor for it, but it has Patriot Extreme Golds with hardened pushrods and stock cam.
Old 11-16-2012, 04:07 PM
Jontall's Avatar
Patriot is out of business now so you may as well use them.
Old 11-16-2012, 04:13 PM
chevybayboy's Avatar
Or get a set of zo6 replacment springs there cheap.. I'd run them if I was upgrading cam other then that you don't need them
Old 11-16-2012, 04:31 PM
J Glen's Avatar
You can still get patriot springs and retainers though.
Old 11-16-2012, 07:39 PM
mchicia1's Avatar
Those springs are garbage. there is a reason they are so cheap.
If you want insurance, get a quality set of beehives like psi maxlife or pax 1218s.
Old 11-18-2012, 07:31 AM
Ronny_02_WS6's Avatar
They will perform normal, I ran them for a few months daily with no problem before the cam install.
Old 11-18-2012, 12:08 PM
Cstraub's Avatar
I'm sorry sir but you are mistaken. Both springs are of very high quality. Take it from someone on my side of this industry.
Old 11-18-2012, 03:20 PM
jmargo's Avatar
I did the Tooley racing springs, pushrods and trunion upgrade a couple weeks ago. Next job is the cam and ATI damper which I wanted to bite off in steps. As mentioned by another poster my valvetrain sound like a sewing machine now.
Old 11-18-2012, 06:30 PM
Sales@Tick's Avatar
Someone that knows their stuff!
Quick Reply: Patriot Extreme Valve Springs, stock cam?
