need a cam for my 4.8 vortec
Old 11-30-2012, 07:48 AM
kad5118's Avatar
Default need a cam for my 4.8 vortec
Wasup ls1 tech I need a cam that will help my 4.8 move my 1980 monte carlo with authority with out losing streetabilty.this setup is going in my 1980 monte carlo with a 200r4 thats built to handle decent power.the car will be a daily driver.what are some good cams that can get the job done.i do plan on having the heads ported,and use the truck intake and also throwing some long tube headers on there.I may run bussani mufflers on there also to complete the setup for exhaust to help the motor.I dont plan of using turbo as of yet
To be clear here are my goals
hp around 340-370 hp at least 340 ft of torque more if possible.
good mpg,
It will be one of my second daily driver.are there goals possible
Please,no get a bigger motor replies please only suggestion about the 4.8 any advice will be well appreciated thanks.
Old 11-30-2012, 04:12 PM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
I would recommend looking at a 212/218 .558/.563 115 LSA cam. This cam will have a broad power band and should have no problems working with a small stall. Should match up well with what you are asking for.
The following users liked this post:
Jeffrojake (01-03-2020)
Old 11-30-2012, 05:40 PM
wildcamaro's Avatar
^^^that cam or something close, I was gonna say 212/216 with lift .575 or something similar...that sized cam will work well on a stock dd..
Old 11-30-2012, 07:47 PM
garygnu's Avatar
consider comp 54-408-11,or 54-455-11.
Quick Reply: need a cam for my 4.8 vortec
