LSx Oil Pan Spacers
LSx Oil Pan Spacers
When building our 479 ci LSx tall deck engine for our GTO shop car we found the need to space the oil pan down to clear the big 4.350 stroke crank.
Since there are no fabricated oil pans available plus they are expensive, we decided to design a 3/8" oil pan spacer to allow the oil pan to sit lower so that the big stroke crank has room to spin.
Our LSx oil pan spacers will bolt up to any LS series block and are 3/8" thick.
You will need 1/2 longer oil pan bolts to use the spacer since you have to add an oil pan gasket for sealing. We are working on a hardware kit but it isnt available yet. The longer fasteners can be sourced at most hardware stores.
The Gforce LSx oil pan spacers are cnc machined from 6061 aluminum to ensure a perfect fit.
The spacers are $179. and are available on our web site.
http://www.shop.gforce1320.com/produ...&categoryId=48
Thanks
Chris
Thanks
Chris
Generally rule of thumb is that your pickup should be 3/8" off of the bottom of the pan, since you are essentially doubling the distance of the pickup off the bottom of the pan do you have a remedy for this?
I know Canton and Moroso make several different fabricated steel pans for around $400 and I think Canton does an aluminum as well. I have no idea about their stroke clearances but it might be worth calling them since they are indeed fabricated pans.
The nice thing about using a stock pan is it still looks stock even though your running a big cube engine
Do you guys sell the pickup as a kit with the spacer? Do you have any sort of baffle kit that bolts into the pan or have you not run into any oil pressure issues? The extra capacity is nice but i've always thought that controlling the oil was more efficient, however i've been wrong before. When installing one of these do you recommend using a gasket on each side?
We havent had any oil pressure issues. a gasket on each side of the spacer is what I would recommend.
Thanks
Chris
