link bar lifters......which ones?
Replacing the lifters when I do the cam in the next month or so. Looking at a link bar lifter set though don't know which ones or why. Cam is gonna be the 228r or similar. Stock 853 heads.
I currently have Morel 5206 lifters. They are very high quality. From what I've been told.... the lifters typically rank in this order:
1. Lunati (micro polishing is a plus over the Morels)
2. Morel
3. Comp Cams
The price of the lifters reflects the rankings to be honest, as with most parts.
2. Morel
3. Comp Cams
Looking at these....http://texas-speed.com/p-597-lunati-...fter-tray.aspx
Correct for my application? I will check out your thread also, thank you.
Morel or Lunati link bar lifters. They are expensive but work really well. have you talked to Don about it yet? when he specs out your cam setup make sure you let him know that you are doing the link bar lifters ahead of time.
