Reputable machine shops-Ohio
Old 02-06-2013, 03:51 AM
Quick Ranger's Avatar
Default Reputable machine shops-Ohio
I'm new to the LS based engines and need a good machine shop that knows these motors in the Cleve/Akron area. I'm looking to have my 5.3 block bored up to 3.898, and i want it done right.I know the block needs a bore, but figured i should just take it to 346 while i'm at it.
I plan on building a 408 on the side later with a TSP stroker kit, but looking to get this thing together somewaht quickly, lot's to do, paint, chassis, custom headers, etc.
Old 02-06-2013, 03:40 PM
Super Moderator
Reckless's Avatar
With an iron block just about anyone should be able to do it. Just get the pistons before hand and bring them with you. Let them know how much clearance you want to run.
Old 02-06-2013, 03:43 PM
Wow, no LS builds in Ohio?
Old 02-06-2013, 03:46 PM
I figured some shops would be more "familiar" with the LS blocks, my normal machinist that did my GEN 1 small and BBC hasn't worked with them.
Old 02-06-2013, 05:11 PM
john563's Avatar
parsons in dayton ohio..if you go on the corvetter forum..tach it up motorsport is a sponsor and they use parsons for for doing their short blocks...another local shop in the dayton area is quick rev..now jim the owner use to have a 99frc that had a 383 that was built by them..the 383 was procharged as well..
Old 02-07-2013, 12:14 PM
Super Moderator
Reckless's Avatar
I used to use Kammer & Kammer (Huber Heights) when I lived in Dayton. They mostly do Mopar stuff, but always did well by me. I know the Ohio Boys have used them a few times as well.
Old 02-07-2013, 04:01 PM
Snkebait95's Avatar
theres a a lot of shops in the cincy area that do tons of ls work
Old 02-07-2013, 04:03 PM
I'll check and see if TEA may have some recommendations since they are a few miles from my house.
Old 02-08-2013, 05:09 PM
94LS1B4C's Avatar
http://www.ipsmotorsports.net/
Old 02-08-2013, 09:09 PM
Go On 3's Avatar
Hutter performance is awesome and is local to us.. 6.0 in my car was done at precision auto machine in canton and its kicking strong 5 years later
Old 02-09-2013, 06:00 AM
Thanks, i'll give Pricision a call. They aren't far at all.
Old 02-09-2013, 06:04 AM
MattKatz's Avatar
Originally Posted by 94LS1B4C
These gys are a performance shop....Not an engine builder.
Old 02-09-2013, 10:34 AM
94LS1B4C's Avatar
Talk to Mike he can point you in the right direction of a builder.
Quick Reply: Reputable machine shops-Ohio
