AI 226cc vs 232cc Heads
Old 02-07-2013, 06:55 PM
67rally's Avatar
Default AI 226cc vs 232cc Heads
I have a set of 243's that I'm looking to get ported to go on my LQ9 build. I have been I touch with Advanced Inductions, along with TEA and Texas Speed and I'm leaning towards AI.
What's the difference in performance between the 226cc and the 232cc porting? They cost the same as the 226cc porting. The website says:
"This is a slightly larger version of our 226cc CNC work that has consistently outperformed other CNC'd GM castings on the market, as well as most aftermarket casting based heads. The 226cc work being only slightly larger than the as cast port, would often leave some areas in the intake port untouched by the CNC cutting tool. While this is aesthetic and does not negatively affect performance, this slightly larger version will minimize or eliminate these areas of "non-cleanup." Most applications will not be negatively affected by the slightly larger intake port, and LS2's & strokers will pick up another few HP over the standard 226cc CNC work. "
And yet no one seems to be running them and I can't get a straight answer what the difference in performance is.
Old 02-07-2013, 07:16 PM
mac62989's Avatar
I know they are pretty new on the site so I dont think theres many results of people running them. Im sure AI offered them for awhile just didnt advertise. The difference has to be minimal and I remember Phil saying stock cube 346 guys wouldnt benefit from it.
Old 02-07-2013, 07:28 PM
HeavyMetl's Avatar
Email him and ask. AI (Phil) does respond to email's, even if it is a few days later.
I recently had a set of 243's ported and a custom can ground through AI, and they we're professional and easy to work with....and they flat out know their stuff. I gave him my piston spec's (-2.7cc, .175 reliefs) and he milled the heads to 57.5, and spec'd a cam that puts me right where I wanted to be with the DCR. I'm impressed and I don't even have the engine together yet!
Old 02-07-2013, 07:57 PM
Tireburnin's Avatar
Send them an email and go with what they recommend. Making big power is easy when you buy the right parts and follow the recipe.
Old 02-07-2013, 08:45 PM
muttstang's Avatar
I'm putting the 232s on my 408...sent em off last week!
Old 02-07-2013, 10:01 PM
dhctss's Avatar
I just bought ai 226 heads. I get them tomorow. There great heads and i saveda good amount of doe
Old 02-08-2013, 05:29 AM
67rally's Avatar
Thanks guys. I have emailed back and forth with them a few times, but that's the only question that hasn't been answered in any of the emails. They have been very responsive to my other questions.
The closest I got was that most people running the 226cc are happy.
I'm just looking to find out if one picks up more top end but gives up some bottom end, or if the 232 is only suited to big bore motors, or FI, etc.
Old 02-08-2013, 09:59 AM
Rise of the Phoenix's Avatar
It would make sense that the 226cc would make more low end torque/power over the 232cc, but the 232cc will make more top end power? What means more to you? Are you ever planning on building a bigger cube engine? If so, it makes more sense to go with the 232cc heads.
Old 02-08-2013, 10:34 AM
redtan's Avatar
I don't think there's much difference. I think from reading their description of the 232 heads, they have fully ported intake runners mainly for those that worry about the cosmetic portion and don't want spots that have not been touched.
I've seen 226 head runners and some spots are indeed left as cast, so the 232 porting takes those out.
Old 02-08-2013, 11:58 AM
Doesn't AI say that their TFS 230cc heads are for a 4.00 bore and bigger? If that is right, then why would their 232cc 243/799 heads be any different?
Old 02-08-2013, 12:10 PM
maxpower_454's Avatar
The cc number is the size fo the intake port. The TFS's probably have a bigger combustion chamber so they're only for 4" bore.
Old 02-08-2013, 01:19 PM
96capricemgr's Avatar
You really need to stop trying to offer advise because you are clueless.
As stated bore size restrictions have to do with chamber and valve size not port dimensions.
Old 02-08-2013, 01:35 PM
67rally's Avatar
I'll post AI's response when I hear back, because I'm sure someone else will have the same question.
FWIW, in an email to Phil I asked:
Also, I noticed on the site that the 226cc and 232cc cylinder head packages are both listed for $995. Is there any reason someone wouldn't opt for the 232cc package on a 6.0L? Thanks.
Their response:
As noted on the description for the 232, it cleans up better and in higher revving situations with larger cams there is some benefit. Most are pleased with the 226cc performance.
My follow up question was:
Is there a downside to the 232's? Are the 226's better in the lower rpm range?
They replied to a couple other q's in the same email, but not that one, so I asked again:
I'm still confused if there's a downside to the 232cc porting vs the 226cc? Could you explain the benefit vs downside of the extra port work?
Anyways, I'll let you know what I hear directly from them.
Old 02-08-2013, 01:39 PM
mchicia1's Avatar
You won't even notice the 6CC difference. Just get the 232.
Old 02-09-2013, 03:03 PM
67rally's Avatar
I heard back from Phil last night:
There should be no downside from running the port, particularly w/ OE style manifold setups etc. The slightly larger port was done because 1. In most cases it should make at least as much, if not another few hp compared to the 226cc work, and 2. Aesthetics. Most guys still go w/ the 226cc work since the theoretical gain is only a few #’s in most applications. Hope that helps!
I waiting for my 243's to arrive from a seller in Texas, and then I'll ship them out for the 232cc work from AI. We had a bit of a blizzard here last night and into this morning, so it may take a few extra days to get the heads to my doorstep.
Old 03-11-2013, 11:44 AM
therat1989's Avatar
Subscribed. Ive been talking with Martin at tick and they are doing the 232cc heads on an ls2 with similar cam specs to mine. Then they can do mine.
Old 03-11-2013, 05:30 PM
Sales@Tick's Avatar
I normally don't play moderator, but that type of response is totally unwarranted. He is just trying to offer advice that is all. Although you are right and he is wrong, doesn't mean you can act like that. Well, I guess you can if you want to, but there is no need.
Yep! We are doing a 6.0 GTO right now that the heads are@AI getting the 232cc port work done! We will be using our SNS Stage 2 cam with these heads so expect results in the next week or two at the most!
Old 03-11-2013, 05:57 PM
67rally's Avatar
FWIW, I ended up sending my heads to Mike at TEA for their Stage 2 port work. Things just didn't work out with AI.
Old 03-11-2013, 06:19 PM
Tainted's Avatar
Regardless of what port service you use make sure to use thread sealant on your rocker bolts.
Old 03-11-2013, 06:30 PM
67rally's Avatar
Thanks for the tip.
Quick Reply: AI 226cc vs 232cc Heads
