My lq4 build, rocker questions
I am building an lq4 w/ a .619/.588 lift 233/240 dur@.050 lsa 112+2
im using lunati hyd roller lifters, ls7 equivelant
brian tooley racing platinum dual spring kit, .660 lift max
should i run a aftermarket roller rocker arm set? Vs. A trunion upgraded stock set???
If so what brand is best? Do the ls7 rockers work well?
Thanks in advance
Thanks in advance
