Valve Spring Recommendation
Old 02-25-2013, 11:30 AM
desormeaux05's Avatar
Default Valve Spring Recommendation
Is .660 lift too much for a GM hotcam?
Old 02-25-2013, 11:31 AM
Tainted's Avatar
go with one of brian tooleys spring kits. that a very reasonably priced and a great quality product.
Its the spring pressures that you got to worry about, not the lift rating
Old 02-25-2013, 12:07 PM
Super Hulk Smash
JakeFusion's Avatar
I think you can use LS6 springs with the hot cam. But I'd recommend a high quality beehive since the harmonics are so much better. PSI 1511 or PAC 1518.
Old 02-25-2013, 10:39 PM
Closed ex-Sponsor Account
sho-me speed's Avatar
PAC springs are a great drop in for this type of application. Give us a shout if you have any questions on them.
Old 02-25-2013, 11:20 PM
Thanks y'all. Sho-me where are you located I live in southern Illinois about an hour from MO
Old 02-26-2013, 03:53 PM
99Bluz28's Avatar
IMO, the LS6 springs are more than enough for the GM Hotcam, but if you want something better then the PAC 1218s($120) would be a great choice. IMO, there's no need to spend more or go with a higher lift valve springs.
Old 02-27-2013, 09:39 AM
Thanx man. I'll look into that what sponsors carry them.
Old 02-27-2013, 10:37 AM
What do y'all think about Brian Tooley Racing spring kits?
Old 02-27-2013, 10:46 AM
Tainted's Avatar
great products prices and support
Old 02-27-2013, 01:34 PM
99Bluz28's Avatar
BTR makes high quality valve springs and I'd normally recommend them, but I'd still think they're overkill with the low lift and mild cam lobe ramp rates of the GM Hotcam.
Old 02-27-2013, 01:40 PM
*02WS6TURK*'s Avatar
Another vote for the PAC 1518's. I'm running them and have had great success with them.
Tainted's Avatar
Id agree they may be more than what he needs, but if you have the money to spend they wont hurt anything.
Old 02-27-2013, 05:35 PM
JPH
JPH's Avatar
Are you wanting a GM hot cam spec but with .660 lift?
Old 03-01-2013, 02:07 PM
I already have the gm hotcam installed it came in the car when I purchased it. And thanx Tainted, that's what I needed I know. I'm glad it won't hurt anything.
Quick Reply: Valve Spring Recommendation
